Stacker 830 or SilervStone TJ09
MajorGN
Hey guys, just a quick question really.
Its coming up for the time for a new build, and I am trying to choose between these two cases. Only problem is as always, how is cooling. As far as I know the Stacker 830 is one of the best cooled cases around, it looks good also, but the SilverStone TJ09 is just that much more sexieh that I am considering spending the extra £25 on it but I need to know..
How is the cooling on the SilverStone TJ09?
Gonna be having C2D, 8800GTX, 2GB Dominator RAM. And it really needs to be cool, The STacker has 4 direct fans on the hardware, so Im guessing the SS cannot be as good as the 830.
Comments appreciated,
Maj
Cooling on both cases are nice. Stacker allows you to put 4 fans on the side panel, and the TJ-09 has a vent on the side panel that allows air into the GPU area of the case. IMO the Stacker is a better choice because it is alot cheaper and cools the hardware just fine, if not even better. Both are great.
both are very very good.
so you are getting a equal case
the only then that matters is
Which Case do you like the most? then after saying that go buy it.
Heh, Mixed opinions means that both cases are pretty damn good. ;)
Silverstone maybe is ideal, Im gonna have a Custom Fan for the CPU, Memory cooling on the ram, and then Silverstone can aircool the GPU, Sounds good.
Is there a comparison with Tempretures on both cases? Guess that would sort the issue out, although I am drawn to thr TJ09.
