Blazestorm
- Jan 17, 2007
I'm looking for a case that has all 5.25" bays on the front. For easy swapping of drives...
The only Lianli case like that, is the A16, I've wanted a LianLi for a long time.
Right now I have an Antec900, very similar... just heavy and ugly
I'm looking to upgrade to something that will last a while..
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119145
Currently Coolermaster is packaging an all-black stacker 810, with a 850 PSU for $250...(On directron) that's a pretty good deal considering I'd spend $160 on the A16 and another $150-180 on a decent 7-800watt PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112132
The Stacker is bigger, cheaper, but steel...
The A16 is smaller, more expensive, but lian-li quality + aluminum...
I plan on getting 3 of these http://www.newegg.com/Product/Product.aspx?Item=N82E16817119403
or possibly 2 of the 5-in-3 versions, although that would be the more expensive route for 1 more drive-bay.
So I guess I'm trying to get opinions one way or the other... I'm leaning towards the Lian-Li just for the quality, but the Stacker is actually looking decent...
This is basically a workstation for HD video editing, media/file server for the raw HD footage and movies/music/videos, and gaming computer all in one... Q6600 + 9800GTX when that comes out...
