Stacked PC-343?
Faldaani
Anyone happen to have photos or a link to a worklog of someone that has stacked two Lian Li PC-343 cubes, or bolted them together side by side?
You are a crazy man if you want to do that! But I'd like to see it too!!!!
Yeah... I know, I need my head examined..
One is too small, or well.. its enough now, but in 6 months? I was hoping someone had done it... I need inspiration :p
Well.. no, it'd be large.
The monster I have on the drawing board as an alternative to stacked cubes would be insanely huge...
Do you think the frame of the cube at the bottom would be able to support the second lian li fully loaded with HDD's (30-40kg) without additional reinforcement? I haven't actually seen one in real life so I don't know how sturdy they are.
