Stack MCR220 with MCR120?
eddieck
So Swiftech has these stackable radiators and I thought what a perfect fit that would be for triple radiator internal water cooling in a relatively cramped P182. From some preliminary measurements (before I buy anything I will do proper ones, of course) I "should" be able to fit an MCR220 in the top of the case. I may also be able to fit an MCR120 to stack at the very end (the side closest to the optical drives). Since I'm using a D14 heatsink I can't fit another MCR220. Will this work?
I'll be using low CFM fans (something along the lines of Nexus or S-Flex) so we're talking around the 1000 RPM area, maybe a bit less. This will be a GPU cooling loop - 5870 most likely, and almost definitely *not* a Fermi (I know if I did go Fermi I'd need quite a bit more cooling power to quietly dissipate half the amount of heat the sun, err I mean Fermi, produces!).
