Stable mobo for X2 4800+
MikroMak
Posting for my friend who's been through hell with his new rig. Its an Asus a8n-SLI Premium with 2x 6800GTs, a X2 4800+ Toledo, and 4gb of Corsair XMS PC3200? He's getting spontaneous reboots or BSODs whenever you tax the system at all, and sometimes they even happen in posting phases, before we even get close to the OS. We've tried two power supplies (both large high quality PSUs), removed one of the 6800s, removed all but 1 stick of ram (and swapped them around), and tested pretty much every part in another AMD system. Some troubleshooting isolated the motherboard as the problem. He's RMA'd the video cards and the motherboard once already.
So what would you guys recommend. Given what he's got he'll take stable over performance since the speed still is going to be pretty good any way he goes. We looked at the a8n32-SLI but I don't really see what the new significant improvements really are and I see alot of people have had trouble with it. We're considering the Fatal1ty board from Abit, the K8N Diamond from MSI, haven't looked at DFI yet but certainly an option.
MikroMak
mhuber@hal-pc.org
I may not be able to help, but i must first ask if he upgraded BIOS? What PSUs are you two using? Which version of windows?
EDIT: just give us all the part's names, vendors, etc.
He flashed bios to 1007, the new tester PSU was an Antec 550 SLI, the original was PC Power & Cooling Turbo Cool 510 SLI, the OS was Windows XP Pro, but we were having reboot issues outside the OS (I had it flip off on me while browsing bios menus).
Edit: We've flashed to the 1009, no better.
there has to be something you guys are overlooking like a 1334 cable plugged into a usb header, or maybe your v core is wrong,something along those lines. Take a deep breath and look at the fundamentals.
The premium is as stable a board as i have ever used
If you take a look around these forums, I'm not the first one to have a few issues, in fact there's a 13 page thread on the subject.
And I'm not so concerned about troubleshooting this board, just lookin for alternate board recommendations
It's likely just a bad board (it happens, even with an Asus board!)
I just got a DFI Infinifty SLI, and am happy with it. Currently running an opteron 165 @ 300 x 8 (so 4800+ speeds) but a single 6800GT. Only had it 6 dyas, but it was the easiest setup I've done in a long while, and no bsod's yet.
I hear reports about DFI's quality and customer service being below average, but I'm a happy user here.
I'd certainly believe it could simply be bad board but my friend must be quite unlucky as he's RMA'd the board once already. he'll probably try to RMA it one more time before just eating it and buying a different board.
Is he running Crucial Ballistix RAM?
I had two 2GB modules in an A8V that kept failing module after module. I finally gave up on them and had them swap them out for standard modules.
I wasn't the only one with this issue. There were several threads on it.
The problem was as you describe. Push the machine, and the memory would fail (literally fail hardware wise) and from that point you'd get spontaneous blue-screens and/or reboots (depending on how that's configured).
-Larry
