Stability Problems
twwen2
Hi guys,
I recently built a rig (specs in my sig) and have been stress testing at stock settings.
I've run SuperPi 1.5, SiSoft Sandra and EVEREST (memory benchmarks) before, they were all fine. However today i installed ORTHOS (dual core) and tried to run the blend test. It failed after 5 seconds, and told me to consult stress.txt, which i could'nt find. So then i ran small FFTs (CPU only) and it ran fine for 2.5hrs till i stopped it. Then i switched to large FFTs (RAM only if i understand correctly) and it failed after 5 seconds again.
I also tried OCCT but it fails after about 20sec too.
I'm thinking that i may have RAM issues, this motherboard (P5N-E SLi) is rather fussy i've read. I actually can't run 4-4-4-15 2T (stock, 1.9-2.1V), i have to use 5-5-5-15 2T (1.8V) unless it will randomly crash. I actually RMA'd the first set of sticks, and these new ones came directly from OCZ. I know that to get memory working well on this board/chipset i need to raise the FSB voltage (it's at 1.25 now), but i can't afford to cause it's only got passive cooling and heats up damn fast. I mean to get a couple of 40mm fans for it, but have'nt got round to it.
I know i should run MemTest but i can't figure out how to burn the disc properly (i'm ashamed to admit).
What i'm really asking is:
1) Can anyone tell me straight off why ORTHOS blend/RAM is failing?
2) Will raising the FSB voltage solve my problems?
3) Can someone run me through how to burn a memtest bootable CD?
Just a side note:
For you overclockers out there i've got the e6300 to 2.7GHz (not much, i know) with stock cooling/voltage, but i'm running back down at stock till i get this stability thing sorted (and till i get an aftermarket cooler - but that's for another thread )
Any help appreciated
Thanks heaps
Antec Nine Hundred|ASUS P5N-E SLi - bios 0401|Coolermaster 650W Extreme PSU|Intel C2D E6300 @1.86GHz|2GB OCZ PC6400 Platinum R2|
NVidia 7300GS (8800 coming soon!)|320GB Seagate Barracuda SATA2
