RobotChild
- Jul 4, 2006
I've been having some stability issues.
Everyonce in a while, while doing something my PC will just restart.
The last time was while playing Oblivion. Once I had loaded up windows I checked all the temps.
Video card - 48 (VF700-AlCu)
CPU - 40 (7000B-AlCu)
And Ambient - Which was 30
I do not have temps for the northbridge, which I believe where the problem lies.
When I hand-tested the temps on all the heatsinks. The NB was blazing hot.
How much would a Zalman ZM-47J help this? (If it is the problem)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=872908&CatId=498
(I'll be picking it up locally. Not TD)
PS - I currently have my AXP 2600+ running stock speeds.
Edit - This is the board.
http://www.asrock.com/product/K7S41GX.htm
