ST20G5 Video Card Options
Fleat
I am curious as to whether anyone has fit an x1900xtx into one of these. I also am wondering whether or not the power supply will power it. I know about the dual slot issue, I am talking length wise and being able to connect the 6 pin PCI-E cable. I know a few things from reading around...
1. You have to cut a hole in the side of the case to fit the dual slot cooler (no issues here)
2. People here "say" you can throw anything at it power wise and the 250watt will be fine (could use an opinion from someone with hands on experience)
Any advice you can give would be greatly appreciated. I can get a paritcularly good deal on ATI top end cards so some advice would be great. Thanks
assuming you cut a hole in the side of the case, it'll be fine. dworley's modded his sn21g5, which uses the same psu, to take a 7900gtx with no problems.
I personally have found that the power supply is insufficient for 2 SATA HDs, DVD, TV tuner card, onboard video only, and External USB 2.0 Hub powering my HD USB PVR box....
