That's not putty doing the line wrap, there is actually a setting in the routers config doing that. Unlike most *nix shells putty can't update any environment variables to update that on the router, so you will have to do it manually.
i use putty and love it, i don't think i understand your problem though? you saying that when you when you resize the window it doesn't move stuff from line 2 to line 1 and vice versa? i don't have cisco router to play with right now but login into a linux i can do a command have it output on lets say 5 lines of screen then make my screen wider and putty will make the output appear on 3 lines
putty updates the terminal size information when its resized.........................
I don't think I've ever seen a terminal that resizes text 'after the fact'. Perhaps shells other that bash do this, because thats all I use and i've never seen the desired behavior.
