1. What will you be doing with this PC?
Streaming TV shows to one or two computers or hooked up directly to TV while streaming to one other computer, music/tv shows/documents storage, web browsing, listening to music, downloading torrents
2. What's your budget?
$400 - $500 (not including case, psu, and os hd)
3. Where do you live?
Northern NJ, there is the Microcenter in Patterson if I do need to get something there
4. What exact parts do you need for that budget?
Thoughts are below
5. If reusing any parts, what parts will you be reusing?
None that can be used with this case
6. What specific features do you need in a motherboard?
USB 3.0, HDMI
7. What resolution output do you need?
1080p
8. Does this system need to fit into a particular space?
N/A
9. How comfortable are you with custom case design/modification and electrical wiring?
Have put blowholes into a couple of A05Ns but likely won't be doing anything modding with this case
10. How important is the noise/silence of this system?
Very
11. How mobile does this system need to be?
Not at all
12. Do you already have a legit and reusable/transferable OS key/license?
Windows 7 Professional 64-bit
13. When do you plan on building/buying the PC?
Immediately to 1-2 weeks depending on when I get the parts
Other option was to get the base mac mini, upgrade ram, buy the extra hard drive kit, and put in another hard drive but the cost would've been $800+ and its not as flexible as building one on my own so I decided to pass on that idea.
Anyways, I was thinking of the following:
case | M350S WITH PICOPSU-80 (would get as a potential buy from someone on [H])
cpu | INTEL i3-2100T ($134.99 on Newegg, $129 on buy.com?)
mobo | ASROCK H67M-ITX LGA 1155 MOBO ($86.99 + $6.98 shipping from newegg), any other thoughts on mobo?
hd one [os] | SEAGATE MOMENTUS XT 500GB (would get as a potential buy from someone on [H])
hd two [storage] | WD 1 TB 2.5” 9.5 MM PORTABLE HD WD10JPVT ($119.99 + $4.99 from amazon)
ram | G.SKILL 4GB (2x2GB) F3-10666CL9D-4GBECO ($30.99 + $2.99 shipping from newegg)
hsf | stock? are there other options available (i.e. what's the biggest HSF that can fit in it)?
os | WINDOWS 7 PRO 64-BIT (already own)
other | M350-HDD BRACKET FOR SECOND HD ($1.95 + shipping from mini-box.com)
cost | $374.91 not including shipping and tax
I've never bought/used a picoPSU before so the obvious question is will that PSU suffice or would I need to get the 90W or 120W variation? I know you've been recommending the M350 Machupo, so let me know what you think! Also, random question but what picoPSU would be recommended for a similar configuration but with i3-540 and gigabyte h55n-usb3? Thanks!
Thoughts are below
USB 3.0, HDMI
1080p
N/A
Very
Not at all
