SSF Barebones
budec
I'm looking for a SFF BareBone system... I went to shuttles site, but they only sell "full" deals.
I'm looking to get (in one package) a Case and a Motherboard.
Requirements:
Need to be able to stuff an APG card in the thing
Need to be able to stuff a network card in the thing (if one isn't included on-board)
Need to be able to stuff atleast 1 hardrive (2 would be better)
1 Bay for CD-Rom drive
Any sites that list theses? I want to throw in a 3.4 (or higher) P4 in the thing... I might go AMD (I like AMD *points to sig*) but not up to date on AMD's current CPUs.
The machine will be used for gaming... so I'm looking for some nice raw horsepower.
Requirements:
nu-aig.
Nearly
Everyone
Wants
Extra
Gigs &
Girls
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-459&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-416&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-425&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-451&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-421&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-423&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-432&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-413&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-431&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-429&depa=0
Incidentally
I have an SN45G with xp2100+, 512mb, 60 gb hdd, r9000 series agp card for sale for a whopping $400 shipped, and it can take up to a 3200+ [officially] and possibly more..
If you're looking for a gaming machine, than AMD should be your only choice.
Since you want AGP, than you've got 3 shuttles to choose from:
SN85G4 (s754) --->most stable
SK83G (s754) --->budget sff
SN95G5 (s939) --->fastest and best looking
You'll be able to fit 2 hdds in any xpc, but at the sacrafice of the FDD drive. If you get a P chasis, I think you can even fit 3hdds (the nForce4 shuttle is coming in a couple of months).
