The 8800GTX will not fit in the Micro Fly without mods as the two PCI-E power connectors can not be connected without interference from the lower 5 1/2 bay.sleepeeg3 said:Heh, I never thought you would find those!It will fit in the MicroFly or JPac. The X-Qpack will be a no go.
Length wise the qpack has more then enough room inside to fit the card. But like the Microfly/jpac you might need to cut into the 5 1/4 drive bays to plug it in.sleepeeg3 said:Heh, I never thought you would find those!It will fit in the MicroFly or JPac. The X-Qpack will be a no go.
