SSD's - Are they "really" long term reliable?
The-Tmann
I am thinking of putting together my main PC w/ a Intel g2 ssd.
I want the speed but am concerned about long term use.
I have had a WD Raptor for 3+ years still running strong and not one issue, I do of course back my goods up.
are the Intel SSD or for that matter any current SSD's truly reliable?
I mean in the sense that I can run my business PC off of them and they aren't going to die or corrupt on me w/o notice.
the answer is probably it doesn't matter. the write cycles should last long enough to buy a massive upgrade for cheap in 2-3 years time.
no doubt you will get a lot of other answers, but the things just have not been on the market to determine the likelihood of issues.
Intel SSDs are reliable enough to be used for most purposes. Is there a chance they could fail and data could be lost? Of course. All data storage devices can fail. That is why people backup important data.
Exactly. I always say that a hard drive can fail at any time regardless of the age, environment or usage. The same can be said for any other data storage method. With that said the expectation is that Raptors will have a significantly higher failure rate than a quality SSD.
Intel claims that their SSDs are significantly more reliable than any mechanical hard drive. Statistically they believe their SSDs will have less than 1% annual failure rate while hard drives in practice have a 1% to 10% annual failure rate. There is an Intel video on this.
Other than failure due to manufacturing defects, unless you write and erase an insane amount of data to that drive all the time (24/7/365), it should still be running fine by the time you're desperate to swap it for the next big thing.
You'll never get over how fast it is once you make the switch, trust me.
Other options are firmware bug or bad flash. I believe all manufacturers are now better at this now.
