SSD wont boot with AHCI enabled.
harsaphes
So i just installed an Intel SSD in my system..W7...If i enable AHCI my system wont boot...It will only boot is IDE is chosen in the bios.
Any ideas?
thanks
usually, if you install on either AHCI or IDE, you can't switch over to the other. make sure this isn't the case
Follow the link criccio gave you. When you install in IDE mode you have to make a registry tweak to load Windows's AHCI driver.
