SSD with P5Q pro?
I have a P5Q-E which has SATA 3Gb/s like yours.
I run a OCZ Agility 3 6Gb/s drive no problem on it, just limited to 3Gb/s obviously...
An SSD, for everyday computing, will be just as fast on SATA 3Gb/s, because the latencies will be good regardless.
SATA 2.0 Mobo and SATA 3.0 drive I believe you mean. :)
Yes you can run a SATA 3.0 drive on a SATA 2.0 motherboard and notice a huge performance increase. I have the exact same motherboard and recently (like last Friday) ordered myself the Mushkin Enhanced Chronos 480GB because I'm tired of putting off my build. It isn't the fastest, and it isn't the slowest, but given I had 3Gbps ports it didn't mean much. It is smoking fast. You'll probably tap out at 300MBps read speeds with any SSD these days, and come close to doing the same on the writes. At least with the drive I bought:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226254
This is what I'm getting with the same mobo but a lower end drive. Mind you I did NOT do a fresh install as I'm waiting for a new build and I couldn't get the re-alignment to work at all. I'd expect all the results to double if I did do a fresh install with aligned partitions.
I have the P5Q WS board which in essence is the same board, and I have been running the Gen 1 Intel 80gb drive for years now and love it. Unless you are trying to do bulk file transfers the majority of the read/write numbers don't mean anything to you. The biggest area of concern is the random IOPs the drive can handle. When you are booting up the OS is reading lots of little files.
Bottom line it will work and you just about can't go wrong with any SSD that was made in the last two years.
Since 2009 I am using a G1 80GB Intel SSD on a P5Q PRO on my linux based HTPC main recording machine. It's probably been powered down for less than 2 total hours since I have installed the SSD in 2009. No problems at all and Intel says the drive has 96% life left in it.
You can ceratinly get a SSD and use it.
But it may not be any faster than what you have. What do you do on this computer?
Unless you are simply using the system to browse the web, it will still feel faster than any spindle drive.
