I've been shopping online for a few days now for a ssd and I like what I see performance wise witht the drives. I seem to be discovering more questions than answers though at this point and I had a few questions that I'm hoping this community can answer. I'm simply looking to use this ssd with the windows 7 I purchased. I talked with some freinds and we all have the same questions regarding a simple setup for this drive which amazingly enough none of us can find on this forum...so without further delay THESE are the questions we have regarding the drive:
#1. Explain to me like I'm a complete idiot how to install this drive from start to finish witht the following setup...brand new installation of windows 7, and the only hard drive is the ssd drive.
#2. Explain to me like I'm a complete idiot how to install this drive from start to finish with the following setup... brand new windows 7 installation with one ssd, and one regular hard drive.
#3. In a windwos 7 clean install does the drive clean itself now with the "auto triming" or do I still need to do any manual cleanup of the ssd (once again explain it to me like I'm the village idiot)
#4. if I currently have an installation of windows 7 on my ssd and want to delete everything and reinstall windows do I have to do anything special to delete all the data? or does windows 7 take care of that? I've seen something about haveing to go into dos to actuall delete all the data... once again... thorough explanation...
#5. in regards to the pagefile issue... if I have 8 gigs of ram or more... with a windows 7 install...what is the safest bet in regards to the pagefile...and what size... not what is fastest but what will work consistantlly and at what size should I set it? I've seen some recommening 400mb to be sure there is enough for error reporting... a general answer along the lines of " go with this stupid... you cant go wrong" would be nice.
I know I'm not the only one who needs an answer to the above questions. personally waited almost a year for the kinks to be worked out and windows 7 to be released just #1 build a 64 bit system and #2 get a solid state drive...answers to the above questions are very much needed and should definitly be stickied in bold crayon!!! if it already exists I simply cant find it, thanks in advance for the answers
