ssd sata3 and p67 speed problem
rxr2
i have MB asus p8p67 and chronos delux 120gb run 500/550 mb/s in atto benchmark but in any others benchmark less than 200/100
i was try many things like upgrade chipset driver, now im runing on Intel_rst_11.5.0.1109_Alpha maybe 2-5% better transfer than 10th series.
when i use marvell onbord controller transfer was in atto the same but in CDM only 180/85!!
on marvel external card asus u3s6 was the same less tan 190/90
in other hand in other review this ssd normally bench in CMD is 480/520 !! link http://www.tweaktown.com/reviews/43...xe_120gb_solid_state_drive_review/index8.html
so WTF is going on about asus and chronos delux !
So is your system working and performing fine and you are just wanting those extra points for your epeen on a benchmark? If so, then run the same exact test with the same exact parameters as in the article.
Upss. i just realize that i have version without delux ( my bad) but this change noting. it should be something like 500/530 link to test chronos like my http://www.xtremereview.com/mushkin-chronos-120gb-review
when i do bench in hd-tune i realize that reason slow transfers in other bech was that for almost time i have 200-250mb/s so the give aprox. 200mb/s
so now the quastion is what to do to make better stabilization in transfers
and be the way it's not about my epeen, i try understand why those bench are so diff.
To have 500MB/s in CDM, you just need to configure it with the 0fill option.
If you have 500MB in any bench, there is no need to bench further, your SSD is working fine (stay on the intel SATA).
Yeah, you need to run the same test with the same exact parameters to see the same numbers.
I have a Chronos Deluxe 120 and it will do 500/250 in CDM. The asynchronous NAND in the regular Chronos isn't going to be able to do much better than what you've experienced without compression. Everything is working fine.
