SSD Samsung and Intel compatibility question
rufik
Hi!
Does anyone know below listed SSD disks are compatible with latest VMware ESXi 6.0 ??
SSD Samsung 850 EVO 120GB SATA3 2,5" (MZ-75E120B/EU
and
SSD Intel 530 Series 120GB SATA3 540/480MB/s 7mm Single Pack - SSDSC2BW120A401
Many thanks
Take care!
What are you asking? If you are asking if they will be seen by ESXi, then the answer is yes since the file system/controller is what ESXi sees. If you are referring to passing UNMAP commands, etc. to them then I would need to look it up. Even that is a question mark until you run the command from what I have read.
Whole purpose is swap OS from usb stick to SSD.
So on this drive will be only Vmware ESXi 6.0
Some newbie question. What is UNMAP ? Is this about reclaim space ? lun?
Why would you want to put ESXi on an SSD? That's a waste - it doesn't need performance for anything.
