SSD Raid 0 Performance not what it should be
NickJames
Just installed 2 Samsung 830 256GB SSD's in RAID 0 and am only getting performance in the 400-500MB/s r/w range. Pretty I should be getting 800+, first time setting up RAID 0 so what am I doing wrong?
ASUS Maximus V Gene
both drives connected to onboard intel sata 6gb ports. Stripe size 128K
*EDIT*
IRST shows one drive as SATA transfer rate: 3 Gb/s and the other at 6 Gb/s, which is odd because they are both hooked up to the same SATA 6G port unless I used the wrong cable..
Going to check.
*EDIT2*
Ok rebooted and now both drives are showing 6GB/s.
*EDIT3*
Ok after playing with some configurations I got it to work right.
ASUS Maximus V Gene
*EDIT*
All SATA cables that were made to spec are the same, regardless of what they are marked as. It is always possible that the cable on the 3Gb/s link is bad/on its way out, so you might want to change that one.
ASUS Maximus V Gene
*EDIT*
Going to check.
*EDIT2*
*EDIT3*
Got a screenshot of a Single 830 256gb drive ?
