I'm using a Intel X25-V 40 GB ssd for windows right now. I bought a Intel 320 120 GB SSD that should come tomorrow.
Should I move my windows partition form my X25-V 40 GB SSD to the new Intel 320 120 GB SSD or do a clean fresh install? If I moved the partition you think it would hurt my performance because the 320 SSD uses 25 NM NAND and the other uses 34 NM NAND?
