fentzinator
- Sep 8, 2002
Just decided to make jump to SSD so I bought Corsair Force Series GT 240 gig along with a Biostar Sata 6 add on card so I can run SSD at 6 Sata speeds. It appears the SSD is not formatted so how do I format it? I have read that you do not format SSDs the same way as HDDs. I know I have to set AHCI in bios and then there is a number of other things to cancel like hibernation, indexing, etc. but did not find how to format before doing fresh install of Windows 7. Also learned that a fresh install is better then cloning although cloning would be so much easier. Didn't realize there was so much to do to set up SSD. Thanks for any advice to setting up SSD.
