SSD Problem in VMWARE ESXi
Marzetti
Hi all,
Wondering if you could provide some insight.
I have 8x 240GB Intel Pro 2500 SSD's on a LSI 9750 in RAID 6.
If the drive type is showing Non-SSD in vSphere client, will that affect the performance of the SSD RAID array? Or is this just a cosmetic factor? I can fix this in CLI, but not sure if it's really necessary or not.
Full ESXi host spec:
2x Xeon E5-2630's
64GB ECC Kinsgston RAM
LSI 9750 8i
8x Intel Pro 2500 240GB SSD's
Supermicro Chassis
ESXi is currently running 9 VM's
Here are a couple links to topics I found on the subject. Doesn't look like it's an issue unless you're wanting to use the array for caching purposes.
ESXi fails to identify a device as SSD
http://kb.vmware.com/selfservice/mi...nguage=en_US&cmd=displayKC&externalId=2008938
Enabling the SSD option on SSD based disks/LUNs that are not detected as SSD by default
http://kb.vmware.com/selfservice/mi...nguage=en_US&cmd=displayKC&externalId=2013188
SSD status is used by ESXi only to determine if disks / datastore can be used for caching or VSAN.
http://www.reddit.com/r/vmware/comments/2v1uqt/esxi_55_shows_drive_type_as_nonssd_with_ssd/
