leSLIe
- Oct 18, 2004
Ok, so I have an SSD, should I disable prefetch?
wouldn't prefetch wear "prematurely" the ssd with all that writing?
After the first loading, chances are if the RAM has not been hit hard that subsequent runs will have a lot of the data already in RAM so disk effects will be minimal, that is regardless of whether or not prefetch is used.
Should I move it away from the SSD?
There are a lot of small writes in there
