SSD + Pagefile
bitsu
I'm moving upto a Intel G2 80gb SSD with a WD Cavier 640 as the secondary for games/apps.
How would I set my Page file? Would I disable it, leave it on the SSD or move the windows virtual memory to the WD Black?
Thanks
Won't the random write/reads eat up the ssd over time and cause i/o?
my os will be windows 7 when i get the ssd.
what would be the fasted solution though?
Thanks
The fastest and probably least time consuming option is to just let Windows handle the page file. It'll stay on the C: drive, and will be sized based upon need. The limited writing capability of a SSD shouldn't be a concern for 99% of home users. The amount of data that you have to move in order to use all of the write cycles is mind boggling.
Two points - set your page file to a set size. There are too many conflicting opinions to cover exactly what size here (I set mine to the Windows-recommended amount even though that's sometimes more than needed). But definitely set your page file size to a specific amount. This saves unnecessary reads/writes when Windows is managing it since Windows will shrink and expand its size as needed. You save a bit in the contraction/expansion by deliberately setting this to a specific size.
Also, don't fret about reads and writes chewing up the SSD over time. I see far too many people trying to insulate their SSD from unnecessary reads/writes and end up relegating many tasks (swap files, IE cache, heavily-used applications) to their HDDs making their OS much slower as a consequence. This effectively renders many of the speed advantages of the SSD moot.
As with any bleeding edge/new technology, SSDs are still in their infancy and more improvements in speed and reliability are yet to come. But if you can afford one, by all means, use it. Don't put it in a safe little bubble and rarely take full advantage of it.
OK thanks, I'm going to set the file to the recommended 9gb on the SSD.
Thanks for all the info and help
