Ok, so, my brother just got this Super Talent SSD to use as an OS drive, and Vista won't detect it (just popped it in first, as a secondary drive, to see if Vista would see it... you know, to make sure it works).
Well, it won't show up in My Computer. The BIOS can see it, and Vista will happily list it in Device Manager, but that's it.
We did some Googling, and tried everything known to man (including enabling Raid in the BIOS, following one suggestion), but nothing helped.
Any ideas? Is the drive just toast?
I don't know what motherboard it is, but it uses SATA 1 (this drive is SATA II, but the manual says it'll work fine on SATA 1) and, if it makes any difference, the drive is plugged into SATA Slot 1 (read that carefully). (The reason we didn't just put it into Slot 3 or 4 is because it will soon house the OS, and be the main drive). I know the SATA slot isn't defective, because, previously, the old hard drive was using it without issue.
We're about the return the drive, but just wanted to make sure we didn't miss some obvious step. All we basically did (as reflected in the manual) was essentially plug in the drive, and boot up the computer. (we messed with lots of settings, but then put them back)
