SSD nOob...help please....
magoo
A few questions.
I'd like to buy a SSD to use for OS primarily. Teamed with normal Sata II HDDs for storage.
First: can I install just the OS and utilities/drivers on the SSD and games and other programs on my "normal" HDD? Is there a distinct advantage?
Second, this would be on an ASUS Rampage IV Formula with Sata II ?
Last: which SSD is the most durable for this use? What size is commonly used?
will I really see an advantage to an SSD?
Thanks, I appreciate the input.
Absolutely!! SSD's are night and day compared with spinners, easily the bottleneck in todays computers. Access times alone are just one huge advantage. Spinners commonly have ~5ms access time where as a ssd can have ~0.1ms and less. Thats over a whole order of magnitude less. I won't bother going on and on, I'm sure you can google the subject and find a ton of resources about the speed advantages.
Anyway, yes install your os and utilities/drivers on your ssd and whatever your favorite programs/games that you use a lot on it also. Then use your hdd for storage purposes of bulkier files like music and pictures for ex. I personally wouldn't go less than the 120-128 gb size. There is a pretty significant speed difference between that and the say 64 gb sizes. Also get one that uses synchronous nand, you won't regret it.
http://www.hardocp.com/article/2011/08/07/nand_flash_faces_off_synchronous_vs_asynchronous/
