SSD might be failing
RyanGSams
I bought a Crucial m4 SSD from the For sale forum last December. I work up this morning and my computer said to pick a drive to reboot. I just turned the computer and back on and it booted fine. I left the house and came back and the same screen came up. All that is on my SSD is my Windows 8 os. I am not very good with working with SSD and am new to them so I want your input on whether you think it is failing. I am hoping it is still under warranty if thats the case.
Thanks
Before doing anything back up your data.
SSD deaths often result in being completely unusable.
It may be a bad connection, try different cables and a different SATA port.
Check the firmware updates to see if this problem is addressed.
