SSD issue with P5Q-E mainboard
Ponder
Ok I have two systems based around P5Q-E. Both pass memory tests and work fine...except... One of the two systems fails if I copy a large number of files to the new Toshiba Q SSD. The other system works well with any of the three SSDs.I have swapped the SSDs and whichever one is in the Quad core system works fine, the one with the duo core fails at about 50 GB of data. Both have 8 GB of ram. I have tried both at stock and their typical OC same results. I swapped out the powersupply on the problematic system. Swapped out every cable. It is problematic with other operating systems as well as the default Windows 7. I have tried changing RED sata ports, but have not moved it to the orange/white ports. I have not checked the thermal compound for the CPU nor the CPU temps, but it handles most games reasonably well, but it is something I should likely check. The Quad system had an SSD before so I might have tweaked the system and simply forgotten something which must be done.
If I go back to pure Hard drives and remove the ssd I can copy files from drive to drive without any problems. Only a problem copying to the SSD from one of the other drives.
