SSD formating/clean wipe
DisrupTer911
Looking to upgrade my system and being that i'm using an OCZ 120GB SSD, what's the best tool to do a format?
In Win7 should I just use the delete partition and format option at the installation screen?
I don't necessarily need to do a low level format, just want a cleaner slate to start on again.
I use SD Erase on my OCZ drives, however if this is a new drive you do not need to worry, just use win disc to partition and format like usual for install.
