SSD for Lenovo X220?
Justintoxicated
Need some recommendations. Just got a message from windows saying that my intel 160 is going bad. Checked Crystal disk info and it says the hard drive is 100% but bad.
Checked the intel tools, and it says the drive is fine except for end to end error count.
I'm not sure what it means but it can't be good tat windows keeps prompting me. Not sure what happened I guess just bad luck?
I was thinking about this one
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=SSD
Not sure if it is compatible though?
Any SSD will be compatible the only thing may be the fit, you can find some that are 7mm with an adapter if you need it.
The X220 has an mSATA slot. I installed a 240GB M500 mSATA drive in mine last year, upgrading from the 80GB Intel I installed when I bought the computer. Works very well, the M500 cost $110 at the time. Between the mSATA slot and the 2.5" you can have two hard drives. I do believe there is a height restriction on the 2.5" drive.
just a reminder:
mSATA on X220 is 3Gb SATA :p..
as long as 7mm (max) SSD SATA... no restriction at all.
mine is m4 msata 256 gig and 2.5 Samsung 830 256 gig..
I know msata speed is capped to 3gb :|.
So I'm not sure what your suggesting? Are you suggesting I should buy an older drive instead of a newer one? I don't think I want to get an mSata drive, that just limits it's use t my laptop right?
He's saying that if you get an mSATA drive the transfer rate is capped at 3gb/sec - a 7mm 2.5" SATA SSD will get 6gb/sec transfer rate if the drive supports it.
If you have a WWAN card in your X220 then you can't plug in the mSATA drive anyway without taking it out - I have both the X220T and X230T which is how I found out :(
just a reminder:
Good point. I think when I bought my mSATA drive the interface wasn't slowing things down much. With newer faster SSDs it may be more of an issue.
Personally I would go with a Samsung 850 evo or pro. I have had great luck with mine, they will fit with no issues.
I doubt you'll notice a difference on a 3gbps interface. Hell, I still use my old 70gb Intel mSATA drive. And my even older Kingston V+100.
I'd go with mSATA just to keep the other drive bay open. mSATA adapters are availaable to use them in other configurations down the road.
I'd go with mSATA just to keep the other drive bay open. mSATA adapters are available to use them in other configurations down the road.
this depends on your scenario
here are mine:
1) browsing and ligh works is nothing differences
2) development (editing, compiling), YES there are differences :D
3) running VMs . YES there are differences :D
my setting is, msata: for docs and pdfs and photos, OS , and other light program
sata 7mm (6g sata) for heavy demanding... as I mentioned on point 2 and point 3.
