FromTheLou
- Nov 2, 2006
I've been seeing some wierd issues ever since I switched over to my OCZ Vertex drive. After initial install Win7 x64, everything seems to work fine for a month or two. But then I seem to get what appears to be data corruption after reboots. Applications won't load and a reinstall is the only way to get them to work again. After a while Windows start failing and the only way to get a useable system is to perform a reinstall. Now after a reboot it takes about 8 mins to reboot while it fixes orphaned files and errors in index entries.
Any ideas on what I can do to a.) prove that this is an issue with the SSD and b.) fix/prevent it from happening in the future?
System info:
i7 920
eVGA x58 mATX
OCZ Vertex (1.6)
System info:
i7 920
eVGA x58 mATX
OCZ Vertex (1.6)
