SSD + Expansion Card Compatibility Question
Discussion in 'SSDs & Data Storage' started by pollo2102, Jan 7, 2020.
  1. pollo2102
    pollo2102 n00b
    11
    Nov 26, 2019
    Hello! This may be an easy-to-answer question, but I am looking for experienced folks' opinions and knowledge. Are these SSDs compatible with this Expansion Card? Are there any known issues or facts I need to know about?
  2. Luke M
    Luke M Limp Gawd
    403
    Apr 20, 2016
    Should work. One is SATA (supplied by the SATA port), the other is PCIe.
  3. Maxx
    Maxx [H]ard|Gawd
    1,551
    Mar 31, 2003
    Yep, keeping in mind you must link the SATA cable to a port. It's not passed through the PCIe connection - the adapter would require a controller (chip) for that.
  4. pollo2102
    pollo2102 n00b
    11
    Nov 26, 2019
    I see. Thanks for the information!
