serpretetsky
- Dec 24, 2008
Do standard hard drive diagnostics tell you anything on ssd's? I can't find much information on this topic, except for some post on the internet somewhere where someone simply said that standard tests do not work at all on ssd's.
I can see how a test that tells you your drive is fine may not mean anything on an ssd since an ssd redistributes the writes to different chips and may not even test all of the flash.
However, what about a test that tells you it failed a read/verify test? Doesn't that mean the ssd has a bad flash cell (assuming your mobo, cpu, mem, and controller have no issues)?
