- Jul 1, 2004
did you see any single case of P256 failure so far?
I have no intention to take a chance on their P256 after reading the hundreds of thousands of complaints in the internet on their SSD drives.
Learn about partition alignment here. Second post has a lot of info.
http://www.ocztechnologyforum.com/forum/showthread.php?p=394853#post394853
Jason
i haven't seen any single case of failure from P256 reported from internet while all other models have failure case reported including intel X-25M, ocz vertex etc.
Have you been on the Corsair forum?
Jason
The new Samsung firmware for P-Series SSD's!
The new Samsung firmware and updater tool have completed internal qualification and BETA testing and has been released.
A couple important notes and warnings: Even though this has been released there are still some reasons why it may not work for everyone:
[1] You will need to use a System or MB that will boot and run Microsoft DOS 6.22 or 7.0 and be able to see a SSD Drive set to IDE Mode. (You cannot use a RAID card or an on board controller set to RAID and run this update)
[2] This tool will only work on Corsair P64, P128, and P256 drives.
[3] This tool WILL ERASE the contents of the drive. All data will be lost. You must back up your DATA prior to doing this update.
[4] This tool has been qualified on X86 Based Hardware ONLY with the above listed restrictions and limitations..
[5] This tool must be run from a bootable USB drive. There have been some users in the BETA program that used other methods but at this time they would not officially be supported.
[6] This update has been developed by Samsung to enable Windows 7 Trim Support on NTFS-formatted SSDs. We do not recommend or support its use on any other platforms.
Please read the Firmware Download Guide (attached) and if you are not able to follow these steps as outlined we would not suggest running this update. This utility is supplied as-is, and is NOT guaranteed to run on all systems, regardless of operating system, CPU, drive format, or other factors. Using this utility WILL ERASE the contents of the SSD being reprogrammed. Use this utility at your own risk; Corsair can not be responsible for any damages other than to the P-Series SSD, which is covered under Corsairs standard warranty. Note that using this utility does not impact in any way the warranty on your P-series SSD.
Hey, what do you know, Corsair released the first TRIM update for Samsung drives.
http://forum.corsair.com/forums/showthread.php?t=83708
Here's the way I see Corsair. I haven't seen a co. that has this deg. of massive recall,
Depending on your motherboard, you don't need to do much. With an Intel mobo, set your drive in AHCI, install Intel's AHCI drivers and you're set. If you're using an Nvidia or AMD based mobo, set the drive in AHCI and use Windows 7's built in AHCI drivers. Also, make sure you have the latest firmware for your drive.
Macmall is an old and very established online merchant, i'm nearly positive you're fully covered by the full mfr warranty, even if it was the unboxed oem flavor i'm sure the corresponding warranty would still apply.http://www.macmall.com/p/Intel-Portable/Removable-Drives/product~dpno~7871487~pdp.fgeaiea This is what I picked up with overnight shipping the total came to $255. This product is in the retail packaging so it comes with full mfr warranty right?
did you see ocz vertex massive recall?
Does this mean the Samsung 256GB SSD might become a worthwhile purchase?
I am not verse in that incident. I don't waste my time w/ these "generic brand" or should I say "brand" name w/o R&D, they are nobody
what brand and which model do you recommend then?
As for advice, DON'T GO CORSAIR. Both the P128 and X128's have failed repeatedly for me - even after multiple RMAs and replacements. I have no idea what causes these failures, but they either fail immediately or after a few weeks of use. Their support forums are full of similar SSD failures and immediate responses to customers to simly RMA the drives. After sometimes long waits the replacement drives come with an eventual recurrence of the same problems.
I think Corsair makes great PSUs, nice high-end RAM and I love their Obsidian case. But purchasing their SSD drives was a horrible and expensive mistake. I wish I could recover some of the $$ spent on these Corsair SSDs to get Intel SSDs instead.
Would you still consider Corsair for memory and PSU?
On a sidente, I have no personal issue w/ Corsair. The thing starts when I do a search at ebay last mth. on SSD. And I notice some Corsair drive that the prices are too good to be true. They have no reserve price on it, it starts at $0.01. That's when I get suspicious. So do a yahoo search on the problems of corsair, and guess what? You don't need to go too far, just w/i their own forums is flooded w/ angry customers. That's when I deleted my Saved search at ebay and understand why they are soooooo cheap
