MisterClean
- Jun 9, 2010
I think I've decided to buy the Crucial C300 SSD, as a main boot drive.
The problem is, I only have a SATA II motherboard (evga 750i sli FTW).
I was considering buying a SATA3/USB3 pcie 1x add in card.
the question is, if I use the addon card, will my pc be able to boot from the SSD?
From my understanding there was a problem with windows machines booting from PCIE drives. Is that fixed? is there anything in particular I need to know before choosing an add-on card?
Also, if it will boot fine, what card do you recommend?
