SS TJ-07 window panel
chronic9
buying a window-less version of the case and would like to buy the window panel... so i looked around and then finally called silverstone directly, the parts guy told me that, yes they have it, its 50 shipped,
butttt!
it might not fit properly because of the unibody design, but in my head i am thinking if its just a panel designed for this exact case, why wouldnt it fit corectly without sanding
has anyone replaced the panel on the TJ07?
One of the panels on my TJ07 didn't fit completely flush when I bought it new. I ended up sanding down the area that was preventing proper fit.
You could also make your own panel like I did. Grab a 12"x24" sheet of polycarbonite form Amazon.
I got the windowed panel for my old TJ-07 and it fit pretty damn near perfect. There weren't any gaps or anything.
The problem for me though, was the finish of the panel. My case's finish (maybe it was an "older" revision or something) was a good deal more matte than the panel which was shinier and had much more visible brushing.
Not a big deal if you're going to paint the case or something but otherwise the two shades of black were really apparent. You may be better off just cutting your own window.
