I'm upgrading from an 8800 gt, and I'm wondering if this will work.
Will this:
http://www.seasonic.com/pdf/datasheet/NEW/Bulk/IPC/1U/SS-520H1U-APFC.pdf
http://www.rackmountnet.com/images/products/ss-520h1u/ss-520h1u_1.pdf
be sufficient to run this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150359
Right now I have an 8800gt, rampage II gene, i7, 6gb of ram and one hard drive running on that PSU. I get a 6 pin PCI-E from the 8 pin EPS http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
I'm not sure where best to get the 2nd pci-e from.
This article:
http://www.guru3d.com/article/radeon-hd-4890-review-test/5
States "Each added 4890 card means another 190 Watt (peak) on your 12 Volt rails. 190/12= 16 Amps per graphics card."
So I don't think it would be wise to split my 12v from the 8 pin EPS connector into two PCI-E.
Should I daisy chain off my case fans? (I'm assuming they're the lowest draw of the 12v rails).
Will this:
This article:
