Squealing Gigabyte EX58-UD5?
I hear a terrible squealing coming from the rear of my Gigabyte EX58-UD5, near the NICs and sound output. It's only present when I'm downloading something.
Edit: On top of that, there's another, quieter squealing that continues even when I'm not downloading something.
WTF, Gigabyte?
My DFI p965s has capacitor singing...it's sort of an acknowledged issue with those boards, and not an indication of anything bad.....
Dunno about that squeal when you dl though, that might explode or something!
It's definitely the NICs, as it stops when I don't download anything.
I'm going to try out this Asus P6T I've got sitting here and get Newegg to refund my money.
Newegg will take returns, right?
Could you clarify what you mean by "those boards"?
Pulled from newegg for your motherboard. This policy appears to be norm at newegg lately. Out of the 20-25 X58 boards listed, only 2 of them had a standard 30 day warranty. The rest had the below, including yours.
Return Policies
This item is covered by Newegg.com's Limited Non-Refundable 30-Day Return Policy.
Return for refund within: non-refundable
Return for replacement within: 30 days
Pulled from newegg for your motherboard (this policy seams to be the norm lately)
Return Policies
Well, shit. Thanks for the info, buddy. :)
Newegg is one of the best for customer service, so you might be able to work something out but that's the official policy.
Why not just get it replaced?
Because after some research, it appears this problem is not unique to me. The representative I spoke with on the phone was very courteous and said that if I had to RMA again, he'd work on letting me exchange it for another product.
Assuming this doesn't fix the issue, what about an ASUS P6t, P6T Deluxe V2, or Rampage II Extreme?
I'd test it out on my UD5 but I don't use the NIC; I use wireless.
Mine squeals also. I got it replaced and so does the replacement. I'm not so sure it's the NIC though, but it's definately something. I have a feeling it's related to the energy saving feature on the board. But either way, I got rid of the squealing by overclocking and taking the voltages for CPU and QPI off auto.
I'll be getting a new one from Newegg in a couple of weeks, so hopefully that's fixed.
While I was running this board, the chipset cooler became incredibly hot -- painful to touch, even. I was under the impression that the x58 chipsets ran cool. Was mine just seated poorly?
I don't know, but now I'm going to have to poke at my heatsink and see if it's an inferno. I have the feeling it might be... so let me know if you solve the mystery. Also, if it was seated poorly, it would probably be cool since it wouldn't be making contact, right?
The way the heatsink was designed (fins are vertical), it's almost as if the design relies on the CPU cooler to push air through it, since not much from the case fans will pass through it. With my processor on water, it doesn't see as much airflow as someone with a heatsink and fan would.
