square pegs, round holes
Briliu
Ok heres my quest
I have a perfectly good AMD Sempron 2800+ Socket A Thoroughbred CPU, many various SDRAM sticks laying around, few ATX cases, vid cards, sound, LAN, fans, yadda yadda yadda
Only thing I need is a MB that will support both the AMD CPU and SDRAM, everything I find seems to be DDR or wont support the CPU
Since I stand a chance to build a bot box with less then 30$ EBAY I would greatly apreaciate any suggestions from you masters of MB
Thanks in advance
i dont know. the problem is going to be to find a socket a mb that supports sempron, and sdram. you might be sol. heres a link to a socket a kt133 board that uses sdram. but whether it supports sempron..........
anyway. if you decide to build a conroe system in the future, i can help you with that. or you can use that very helpful resource "the intel conroe overclocking database" . if you go there, check out the retail 6...............
I run an Asus A7V (socket A and sdram). Not sure how fast a cpu it supports. I believe the next evolution of this board went to DDR.
My first Athlon rig had an Asus A7V133. SDRAM plus a TBird meant juicy goodness for JK2 and RTCW :D
