Square fan grilles?
Thaddy
I was staring at the top blowhole on my PC-60, and I started thinking if there was a way to get a square fan grill, something that would be less restrictive. I don't want to cut out a circle, since I want to keep the clean lines and square theme that Lian-Li has with this case.
make your own!
use some of mnpc's modders mesh
or you could use one of those square fan filters
they do make square grills but they are plexi with LEDS. I think the major modding stores carry them.
i saw some squar fan filters a while back which is a bit more usefull anyways.
Plenty of plastic or metal mesh square fan filters available. so-trick has some colors avail on the mesh ones as well. If you want to make your own from mesh - head down to Lowe's or Home Depot and get some gutter screen.
