Can anyone recommend a product just like the adobe classroom in a book but for SQL or Access?
I have a DB/SQL class this semester and a class in Access but the texts for those classes completely suck. I need something like the adobe classroom in a book where there is a step-by-step process that produces results. I used the Adobe classroom in a book back in high school to learn PS, Illustrator, and Page Maker.
I'm stuck learning SQL and access because all I have are syntax manuals and no projects to work on and learn how to USE the technology. I just need some type of classroom in a book type thing.
I have access to 8i on campus so I can create tables in that and then do queries there. I'm using open office db for access and it works similarly but I'm stuck on both Access and SQL because I know how to create tables and make a query but I need some practice material. The Adobe classroom in a book has projects you work on and then they teach you how to use the tools to do stuff. I need something like that.
That's it, I think I need a practice manual or something with projects and queries to be made. That's all. I'm sure these exist, but I don't know anything about how to get one. I have plenty of time to mess around in sql and access but nothing really to do. Plus I have tests coming up in access and sql.
Edit: If I don't find anything I'll probably just end up making up my own data tables and relationships and then just creating problems for myself to solve. How silly that would be. I need to sit down with my professors and tell them they need to teach use what the hell we're doing instead of talking about genetic algorithms.
