Spyder 5 Pro question
zerocool72
Does anyone know if you use the Spyder 5 Pro, do you need to have that utility running on the taskbar all the time or can you disable it from starting when windows starts? This is after you calibrate the monitor of course. I'm just not sure if I disable it if my calibration settings will load with windows if I stop if from loading when windows starts...
After calibrating, if you save the config file (I forget what it's called) and set it as default, Windows will always load that file on startup. The software is only needed to perform the actual calibration.
Don't use the crap it came with. Use dispcal GUI.
