Riccochet
- Apr 11, 2007
Picked up my Epic yesterday.....best choice I've made in phones yet.
I'd rather not void my warranty, plus I have best buy's black tie warranty. If something happens to it I'm pretty much stuck paying $650 for a new phone.
Question. Since having my Epic I've noticed battery life to be teh suck. Meaning, I get about 2 hours of use before it's deadski, maybe 3-5 on standby. I have the app killer and run it every time I'm done using the phone. Common problem? Also takes forever to charge. 2-3 hours on the wall charger. Good freakin god.
First off, stop using Advanced Task killer. I can't stress this enough. Secondly, root your phone and install the SDX App Remover, then remove the DRM services that Samsung has running in the background. Autostarts is another app that can block these from starting up, but SDX remover will get rid of them completely.
In addition, go into your wifi advanced settings and change the wifi to "never sleep". You'll notice a HUGE increase in battery life after this one.
Turn it on. WiFi uses less juice than the CDMA radio. Also, my Fascinate takes 2~3 hours to charge IIRC. I can kill it in 7 hours though if I'm on it nonstop.Additionally, I don't have my Wifi even turned on. Sometimes I use it while I'm home, but mostly it's off completely.
Why does ATK chew up battery life?
I still don't understand why it takes 2-3 hours to charge. And that's a low end figure.
http://geekfor.me/faq/you-shouldnt-be-using-a-task-killer-with-android/
Obviously, turn wifi on when you're home, turn it off when you're not.
As for your low battery time, I have a feeling you were one of many hit with the common CDMA android bug. Go into settings, then about phone, then battery use. Check the "cell standby" percentage. If it's above 5-10% or so, you're affected by the bug, and it will SERIOUSLY drain your battery. Basically, the phone is looking for a WCDMA tower, which it will never find, and it burns the battery quick. To fix, when you boot up, turn on airplane mode, wait 10 seconds, then turn airplane mode off.
Also, I have to reiterate, rooting your phone and removing the DRM crap mediahub adds to your phone will almost double battery life as well.
...what good is Wifi going to do me...
Unless you're shutting your phone off or disabling syncing services and apps, it's using more power on 3G than it would on WiFi. Especially if it's constantly looking for signal. I'd recommending doing what Entrop mentioned and setting WiFi sleep policy to never as well.Obviously, turn wifi on when you're home, turn it off when you're not.
Interesting, I've never read that before. IIRC, mine's well above 5~10% as well. Any idea if the mediahub's an Epic only thing or does it run on the Fascinate as well?As for your low battery time, I have a feeling you were one of many hit with the common CDMA android bug...removing the DRM crap mediahub adds to your phone will almost double battery life as well.
Epic 4G Android DevelopmentHave a guide on how to root my phone and remove the DRM?
IMO it's still a good idea to task kill on boot. It wipes out a lot of stuff that doesn't restart, but isn't safe to remove, either.
Well, is it like an app that says, "media hub" or something else?Jodiuh, not too familiar with the Fascinate, but I'd check XDA to be sure. Don't want to give the wrong info out here.
