Spring cleaning - advice?
sc00ter
Springtime is coming, trees are flowered, HDD's are fragmented and cluttered. For this years spring cleaning I plan to completely format my HDD and start fresh. However, I would like some advice on how to do so. I have two HDD's, both 160GB; should I store pictures, music and the like on my second disk while putting my OS, games and apps on the first? I'm open to any suggestions! Thanks,
-sc00ter
My rule of thumb is any DATA goes on the slave, and applications, games, OS, etc go on the master.
Anytime you download a patch or a file, it goes on your slave. Any pictures, movies, music, documents - on the Slave.
OS, Games, Apps - basically anything you install, goes on your C drive.
