Sporadic HD Noise when using Vista..
Cerdinak
Hi all - I hope someone might be able to point me in the right direction of fixing this, as I am a bit perplexed. A brief overview of my problem -- sporadicly a hard drive in the system will whirl up / make noise - causing the system to become unresponsive for a really short period of time - The problem ONLY happens in Vista. (Example would be, I am in WoW - the screen might freeze for a really short period only to come right back, it coincides with the HD noise)
The problem happens at any time; sitting at the desktop doing absolutely nothing - no extra programs loaded. The problem doesn't happen constantly either; It can happen once and not happen again for another 3-5 hours - or it can happen a few times in 1 hour. The sound the HD makes reminds me of a laptop coming out or going into sleep or hibernation.
Here some system information:
I have a dual boot system - WinXP Professional and Vista Home Premium (32 bit)
Gigabye GA-965P-DS3 with E6400, 4 gigs (3.5 addressable)
Ega 8800gtx
2 Drives in the system;
1) 150gb WD 10K (WD1500ADFD) - XP drive (Boot Drive, contains the Bootloader)
2) Segate 320gb (ST3320620AS) - Vista drive
Both drives check out fine, no errors or issues when I chkdsk them. Again, this problem does not exist at all while using XP - it is vista doing something.
Ideas?
Thanks!
Vista is not an idle OS like XP.. it is constantly doing things like indexing and defragging.. it's normal. If it really bothers you that much, you could change your power options.. Go to Control Panel, Power Options, under "Balanced" select "Change plan settings" and then select "Change advanced power settings" select "Hard disk" and then "Turn off hard disk after", and change it to "Never".
That will prevent the disk from spinning down. Understand that I am not necessarily recommending that you do this, but you can..
Three words:
It's perfectly normal.
Ok, so two words and a contraction, so what... :p
As just noted, Vista doesn't sit still as most other OSes do including all the previous versions of Windows. It's how things are done now, so get used to it, and in the long run you'll have a better and more efficiently operating computer overall.
Have you found any errors in Event Viewer? Specifically the System logs.
See if there is any iastor errors or an error 51.
You have enough horsepower there, you should not have to deal with pauses caused by the OS.
Thanks so much, I had it set previously to High Performance thinking that means - no sleeping. *boggles* not thinking to check the advanced settings. High Performance without advanced customizations means HD will sleep in 20 mins and "studder" the system. I fixed it as suggested (setting it to Never) and It seems to have stopped! thank you!
