[Sponsored] Project Metallic Sky
Status
Not open for further replies.
MapleSyrupMods
Bring on Titan X Volta
Project Metallic Sky​
Personal Introduction
Hello Everyone! I'd like to start off by introducing myself. My name is Nathan, better known on Instagram as @MapleSyrupMods and I'm a PC Builder based out of Canada. I've been building PCs for the last 17 years, but only recently started documenting them in the last few. Well I am new to posting here, I am not new to these forums. I have been browsing them for years but never been one to post.
Now that that's out of the way, lets get on to why your viewing this thread.​
Build Introduction
For this build, I have chosen to go with a royal blue/silver colour theme. The idea behind these colours is to create a very clean(ocd, p0pe level), simplistic and high end look. The modifications to the chassis will be very subtle. From this, I have chosen to go with the following parts; But first, I would like to thank the companies that have sponsored me and entrusted to build something that they can be proud to say the represented.​
Sponsors
AMD​
Hyper X
Main Frame Customs​
Hardware
Case - Phanteks Enthoo Evolv ATX Glass - Galaxy Silver
Power Supply - Corsair AX860i
CPU - AMD Ryzen 1700X
RAM - 32GB Corsair Vengeance RGB LED DDR4 3000Mhz
Motherboard - Asus Crosshair Hero VI
Hard Drive - (2) Hyper X Predator 960GB M.2 drives
Graphics Card: NVIDIA GeForce GTX 1080Ti
Watercooling:
Fittings - Bitspower 12mm in Royal Blue
Waterblocks - EKWB Crosshair Hero VI X370 Monoblock
Radiators - EKWB SE 360 & 240
Pump - Laing D5 with Bitspower Royal Blue MOD kit
Pump Top - Bitspower
Reservoir - Bitspower Acrylic 150mm
Tubing - 12mm copper chrome plated hard tube
Fluid: Mayhems Pastel Grey​
Begin:
The build on the front and back side of the case will look very minimalistic. I have used Hans Peder Sahl(p0Pe) as an inspiration for this build and he has graciously assisted me with some ideas which you may see some resemblance. He is a master of clean looks and a man after my own heart. The cable management is where it will really stand out. I have always enjoyed making custom cables for my builds and have a pet peeve for extra unneeded cable.
I will forego your typical stock box photos as anyone reading this build thread has already seen what they look like. Let's skip to the pictures where I have assembled them onto the motherboard for validation.
Water Blocks
Now that the system components were validated and everything working fine, barring a update to the bios to get the RAM to run at correct speeds, I took some time to get the EKWB Monoblock installed. I've always liked the look on the monoblocks and decided that this would help bring some silver back into an already dark board.
It definitely does not disappoint
Installation is straight forward, and found everything easy except for screwing it in on the backside. Seem's there is no easy way to install this as you need to hold the block in place, hope that its centred and flip it over. What I did was align the block on the board and put the board on the motherboard box. This allowed me to slide the board 2/3 off the box and insert the screws without risking screwing up the thermal pads and thermal paste.​
No longer needed
With the Monoblock installed, Over the weekend, II will be sleeving the RGB cable for the LED's on the block, as well as installing the water block on the GPU. Here are a couple pictures to show the block installed as well as an idea of where I'm headed with two of the fittings installed.
Reactions: drklu
Status
