eternalvendetta
- Jan 12, 2006
I have a pretty decent-sounding set of speakers, and I'd like to be able to hook up my PC, XBOX 360, and PS2 to it (I have all three connected to my PC monitor, which has no speakers, which would output junk anyway). The problem is, the speaker system only has one input jack.
For the 360 and PS2, I'm using 2-RCA-female-to-3.5mm-female cables. I really haven't found much in the way of a 3.5mm female-to-2-male (or 3-male) splitter cable aside from a select few on eBay. What are my best bets for finding one online or otherwise? Radioshack seems like the place that'd have it.
Also, are there any negative effects by using such a cable? I read something along the lines of one of the outputs being stereo and then the other two outputs being mono. Also, can I connect the cable to another cable of the same type to allow for three inputs like I'm trying to get? Would that further degrade the sound quality? Thanks.
