Split ergonomic keyboard with detached numpad?
I have a Goldtouch keyboard. It lets you change the angle of the split and the center elevation (up to 30° each). They also make separate numpads but I don't have one. Otherwise it works like a laptop keyboard where you hit numlock and certain keys will act like a numpad.
It took a little getting used to, since the non-QWERTY keys are arranged a bit differently. But it's quite comfortable and has a nice tactile feel. :)
That's awesome; I'll look into it. Thanks for the reply; never seen anyone else ask this.
What's that swivel looking arm at the top?
Yikes, these are expensive; ebay has a few but with shipping they're still costly.
That thing at the top is the tension lever that allows you to set the adjustments and then lock them into place.
Check your PMs, I believe the guy I bought mine from might have another at a good price. :)
