phobic said:Possibly the best Splinter Cell yet. The demo looked and ran ver well on my lap top at max details. I like the music Amon Tobin provided too (considering I've been listening to the game's soundtrack for about 2 weeks now.)
Michael.R said:what settings are you guys running it at and getting for FPS. The shader 3.0 with HDR is awsome but it hogging my FPS. I got to make the choice between HDR and AA/AF.
peltman78 said:So anyone know what version of shader this game is using on ATI cards. Heard a rumor that it either uses SM3.0 or 1.4 with nothing in between. Can anyone verify this.
Thanks
Thanks
ThomasE66 said:Now I'm even happier that I have SM 3.0![]()
Michael.R said:Ya it looks awsome. I just cant figure out what to take screenshots with so I guess I will have to use FRAPS. (but i can only save BMP)
Edit: NM the images come out at at nearly 4mb's and I dont want to resize them because the look nearly the same after you end up resising them. But 3.0 looks much better then 1.1 after trying them out, its mostly the HDR though.
fallguy said:A FPS counter would be nice. One poster did that, and showed he went from 43fps with 1.1, to 18fps with 3.0. That may not be worth the FPS hit, depending on who you ask.
It would also be nice if they stopped being lazy and added 2.0.
ManCannon said:Nope, one of the options in the Shader 3.0 settings is HDR.
Sounds simple enough. Thanks for the tip!ManCannon said:To enable HDR in the Chaos Theory demo you have to enable Shader Model 3.0 in the advanced video settings tab. I think it enables HDR by default, but to be sure you can click on the box next to your Shader Model selection, I think it says something like "Shader configuartion" or something. It's in there.
