dobieg2002
- May 7, 2007
I'm running a dual Xeon 5440 and a HD3870 It is running well. The only question I have is @ what CPU load does Speedstep/C1E start raising the multiplier? I'm running everest in the background and loging the info to HTML.
I'm benchmarking the sytem with Crysis, 3dMark06, Lost Plannet. 90% of the time while benchmarking the CPU is running @ 6 multi. 3d Mark will go to 8.5 when it is running the CPU tests. Crysis is only using 10-20% usage of each core 20% total and stays at 6 only once or twice was it recorded as going to 8.5 for a brief period. Lost planet never goes to 8.5.
Is this normal. My Q6600 goes to it's default multi whenever I do anyof this.
Thanks,
Thanks,
